The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
137 Questions View all
Motherboard Replacement / Upgrade
I have been given a 11” MacBook Air early 2015
It needs a new Logic board. Looking inside I see it has the i5 4GB of RAM.
Can I upgrade to a motherboard with the I7 and 8 GB of RAM with no issues?
I have seen varying answers online saying it needs to be the same year. Please advise!
Add a comment
1 Answer
Chosen Solution
Generally, you do need to stay within the systems series MacBookAir7,1 as Apple tends to modify things enough with the connections on the logic board as well as the mountings between the different series.
So in this case the 2.2 GHz Core i7 (I7-5650U) board would be your first option. This is the best board Apple produced for the 11” MacBook Airs before Apple redesigned the system so radically.
You could use a lesser board from Mid 2013 and Early 2014 as well as Apple stayed with the same hardware and connections MacBookAir6,1
Score 1
1 Comment:
Amazing thank you for the info!
by
Add a comment
Add your answer
GFarrell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 76
