No backlight display; what are possible causes
I've replaced a broken lcd on a working MBP A1226 twice with new display units. I currently use an external display as my monitor. Both replacement display units (clamshell) had the same problem of not having backlight on LED. I can shine a flashlight on the display to confirm that the LED is functioning properly.
Here are what has been suggested as possible causes of the issue:
1) Bad Inverter - could I have had two bad inverters in a row when purchased used displays that supposedly tested ok before shipping?
2) Bad Inverter cable - the backlight does not flicker on/off when wiggling the display. could I have had a bad inverter the first time and a bad cable this time?
3) Bad magsafe board - I bought this laptop with a bad display already. Maybe the magsafe board could have been damaged at the dc-in connector only. Everything else on the magsafe board works, including the sound, wifi and USB ports. The charger seems to also be working. The battery has a low cycle count and seems to charge fully do it does come down to 97-98% while plugged in on occasion.
I know this will be a process of elimination but wanted to see if there was anything I could do to test certain components before tearing into the laptop. Can I test the power on the pins coming out of the magsafe board to confirm the right current? If so, what should I measure?
Is there is anything I can try that is less invasive or can narrow my issue to a specific component or part?
I've reset the PRAM and SMC. I've tried it with battery power and with AC only. No change.
Thank you in advance for any information.
1 Comment
You said you've replaced the LCD, are you talking about the screen or the whole top unit. You also stated "could I have had two bad inverters in a row" but do not mention replacing them. Please describe your efforts with the inverter.
by mayer
