Released in May 2018, identified by model number X410ULMG.
13 Questions View all
My charger keeps falling out and it has to be just right to charge
My LG k30s charger won't fit into the charging port and I've used multiple chargers and it's the same with all of them. Ive looked up how to fix this and every article says there's dust and stuff inside my charger port…there is not, I even tried “removing" what what could've been there but there was nothing. This isn't a new phone or a new charger either. It worked and charged perfectly and then one day it became loose. Please help!
Score 1
Add a comment
Chosen Solution
Do you have a case or rubber / plastic sleeve on phone? Try removing that and using a new micro usb charger not from 99 cents store they are made cheaply and easily break. I had same problem doing these 2 easy steps helped another tip dont use phone while charging!
Score 2
Add a comment
From what you've described, your USB port is damaged. I had a similar problem with my Blackberry and the only successful repair was replacing the Port
Score 1
Add a comment
My life sucks beacause of this
1 Comment:
Jacob Long unsuck your life and fix it:-) What phone? What issues? what have you tried?
by
Add a comment
Add your answer
cooper unkown will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 15
Past 30 Days: 65
All Time: 2,316
