The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
136 Questions View all
My MacBook Air hasn’t been turning on in 3 days! Please help!
On Saturday morning I woke up and my MacBook wouldn’t turn on. I’ve tried smc and pram resets already but nothing seems to be working. The only cause I could think of is that I spilled a bit of water on the touch pad but it should have dried up by now. I’ll attach a picture under the cover of it. Please help.
1 Comment
It doesn't take much ;-{
Tap water is not clean! It has minerals and salts which are still present on the surfaces after the water has evaporated. Bottled spring water is often heavy with minerals!
by
Add a comment
1 Answer
Most Helpful Answer
Given where you spilled I suspect the Touchpad got wet and the corrosion maybe limited to it. Here’s the needed part MacBook Air 11" (Mid 2013-Early 2015) Trackpad and here’s the guide you’ll need to follow MacBook Air 11" Early 2015 Trackpad Replacement
I would start there
MacBook Air 11" (Mid 2013-Early 2015) Trackpad Image
Product
$109.99
Score 1
Add a comment
Add your answer
Aaron Quan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 66
