Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1503 Questions View all
Unlocked 3G unknown error 1015. Help. Thanks!
Ok. I hacked the Iphone 3G. By mistake I erase all content and Settings. Delete Iphone. Thats what I did. Ctc apple and they told me to:
1. Disconnect phone and start iTunes.
2. Connect phone to a USB port on the Mac, not an external hub
3. Press both home and sleep/wake buttons until the Apple logo reappears, then continue pressing the home button alone until iTunes detects the phone in Recovery Mode.
4. Follow the prompts to restore.
Depending on how your phone was hacked to unlock, this may not work and may get error messages. Write down the message. You may have to Google to find "alternative" methods that can't be discussed here.
This didnt work, get unknown error 1015.
What should I do??
Did all of the above.
Thank You so MUCH
LIN
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
Error 1015 is usually a downgrade error. If you have installed the iPad baseband to unlock then this explains it. If you now have the iPad baseband, you will need to Restore your iPhone with a Custom Firmware made with the help of one of two programs. If you have a Mac use Pwnage Tool, if you have Windoz use Sn0wbreeze. If you still have Error 1015 problem use program TinyUmbrella to Exit Recovery. If you do not have the iPad baseband, then just use TinyUmbrella to Exit Recovery.
Score 1
Add a comment
Add your answer
LIN will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,240
