Guides and support for various television (TV) brands and styles.
9046 Questions View all
Plasma Television with no power, no red light.
This is in reference to a Panasonic TH42PX6U Plasma Television.
After about 3 years, one day out the blue, the TV wouldn't turn on. The red LED light would blink 10 times and repeat. I did some research, and the most recommended response was to replace the P board (power supply board).
During the week or so of my research, all of sudden the TV completely died! I would plug it in, and no red LED light at all would come on.
I figured the problem might still be the P board, so I went out and bought one anyway. No luck! I replaced the P board and still, there is absolutely NO POWER. No red light, nothing happens when I plug it in.
I know there is a lot of information regarding the coded blinking lights, but what is the problem if there is no light at all? Any help would be much appreciated.
Thank you
Score 3
Add a comment
Chosen Solution
Kingofdenail, not sure where you are with the repair of your Panasonic. Just in case, I attached a flowchart showing what to check for. So check the PA board and the H board...;-) As you probably know, this type of repair can be complicated and cumbersome, and can lead you astray many times. I am not sure if the service manual and the supplements will help you with it, but I uploaded them Right Here Hope these will help you out and get you going in the right direction.
Score 4
Add a comment
says refer to 9.2 wich isd where
1 Comment:
Hi @mercy1
It was probably referring to a different section of the manual which was posted in a download area, but since it was posted 5 years ago it is probably now gone.
Here is a link to the service manual for a panasonic TH-42px6u
http://elektrotanya.com/panasonic_th-42p...
To download the file when the sentence below the Document preview box changes fromThis file is downloadable free of charge: ...processing... to This file is downloadable free of charge: Get Manual, click on the Get Manual, as this is the download link. Be patient it takes a little while to find the file.
Hopefully this will be of some help.
by
Add a comment
Add your answer
Kingofdenail will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 18,601
