Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Question Closed
iPhone won't turn on!
I have an iPhone 3G 8GB. Basically the iPhone was accidently run down to 0. Then when I came to turn if back on it woudln't. I've replaced the battery and that hasn't changed anything.
Basically, if I plug in a connector cable that is connected to a USB I get a silver Apple logo appears on screen for a minute or so, then the display disappears apart from a very faint Apple logo (almost like screen burn) until I unplug the cable, then it disappears completely.
If I try and put it into DFU mode, it comes up with the Connect to iTunes graphic. I connect to iTunes, iTunes recognizes a device is in DFU mode. I try and restore but it fails instantly with an Error 23. It then disconnects itself.
Does this sound like this an economical thing to try and fix, seeing as I can get a 2nd hand 16GB for £250?
Add a comment
Most Helpful Answer
From what I can tell searching some other forums, etc, it sounds as though your iPhone is bricked. Was your device jailbroken? I found this information which might be helpful:
"I was able to fix error 23 by deleting the backups on my laptop and restoring w/o an existing backup. The problem was one of the backups was corrupted. You can find the backups under the Preferences -> Devices tab in iTunes. But I got error 1011, that is not to bad."
Score 1
Add a comment
Thanks for your reply Brady. No, the iPhone isn't jailbroken or unlocked. I've tried doing fresh restores on two other computers so I can't see it being a corrupt backup either. So it looks like the iPhone's a goner then!?
Could it simply be that the Logic boards busted? Is there any point in trying anything else? Is there anything else that I could try?
1 Comment:
It could indeed be a bad logic board but that would be far from simple. That part is nearly impossible to obtain from a reliable source. Sorry :(
by
Add a comment
How are you charging it??
charge it from the mains instead of the comp it thats what you are doing and leave it for a good while...should be as simple as that if it wasnt damaged and you just let it go flat!
Add a comment
my i phone swich off please tell me solution of this rectificatin
Add a comment
my phone switch off please give me solution
Add a comment
i cant understand what are you doing
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,830
