Model A1288 / 8, 16, or 32 GB capacity
583 Questions View all
Repaired iPod Touch screen not locking in.
I just spent the day taking apart a friends iPod Touch, now I'm on to putting the fresh new screen back on...and I run into this problem.
The screen doesn't seem to be locking in place. It seems when you're pushing it, that something's blocking it from locking into place, but there's nothing blocking it. What do you suspect the problem to be?
Add a comment
Chosen Solution
This particular digitizer needed to be pushed pretty hard to get it to clip in, and that's all I did to fix this problem.
Add a comment
Did you break off any of the clips from the plastic midframe? They could be stuck, preventing it from closing. It's also possible that the lcd is not completely aligned (try holding the digitizer slightly away from the ipod and seat the LCD in the digitizer, then close the ipod by pressing the metal back to the digitizer).
Comments:
It turns out I just wasn't pushing it hard enough. Pushing it harder could have been potentially worse, but it worked out this time. Thanks for your time!
by
Add a comment
hello
i purchased and iPod touch 4th generation and my screen glass broked
but my screen would still work i order a screen on the internet for the replacement of the screen but as i installed it started with a White line on the left side of the screen but as time went on the whole screen turned White
is there any recomendation to this case?
Add a comment
Add your answer
grahambargeron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 570
