Screen works only when kept in certain angle
the screen has gone bad and doesnt work till i bend it to certain angle. do i need to replace screen? how much is it?
This is usually caused by a damaged Display Data Cable. Replacing this cable should solve your problem. Please give us the last three figures of your serial number so we can determine which machine you have and direct you to the correct part and repair guide. Thanks
Thankyou for the response. Its a 2ghz Intel core 2 duo and the Serial Number (system) is YD927ZWM4R1
Apple MacBook "Core 2 Duo" 2.0 13" (White-09) Specs
Identifiers: Early 2009 - MB881LL/A - MacBook5,2 - A1181 - 2300
Here's the guide for replacing the cable: MacBook Core 2 Duo Display Data Cable Replacement
Here's the part: MacBook Display Data Cable
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 624
