Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1952 Questions View all
Why is phone only able to go into DFU mode?
Phone won't turn on, only get black screen, and able o get into DFU mode, iTunes sees phone in "recovery" mode. I want to get it to boot so I can use Disk Aide to get data off the phone. It has the red water damage dot in dock connector.
I have tried tiny umbrella to kick it out of DFU mode, and then it disconnects from my Mac, and still has black screen. This is a 32GB model running iOS 4.1.2.
Is there a way to get it to boot?
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
try replacing the damaged dock connector so that you can charge your battery fully. if the battery isn't fully charged then it won't be able to communicate fully with your pc. the pc won't provide enough power to do the restore. dfu mode will delete you information..
Score 1
Comments:
^ this, may be encountering voltage issues from the water damaged dock connector.
by
Add a comment
Add your answer
Jerry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 554
