The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
150 Questions View all
Soldering small touch connector
Has anybody replaced the small touch FPC connector on the iPad 6?
I noticed this style connector doesn’t have the legs protruding out wards but attaches directly underneath.
Any pointers?
Thanks
Add a comment
1 Answer
Chosen Solution
You’ll have to solder it back using hot air. This, of course, presents its own challenges ;>).
The trick to soldering plastic connectors with hot air is to:
  • insure the board is properly cleaned and the pads tinned
  • then pre-heat the area of the connector, apply some flux paste and align the connector so that the metal legs are sitting on the tinned pads.
  • then apply heat but not too close as you don’t want the air flow to blow the connector off the board
  • keep your eye on the plastic, if it starts melting then you are too close, too hot or the airflow is too high (this is the part that takes the most practice)
  • once the pre-tinned solder flows, the connector should fall into place…adjust it slightly with tweezers but don’t apply any pressure on the plastic itself as it is very soft at this point.
  • expect to go through a few connectors at first, the slightest mistake will cause the connector to melt or warp.
Good luck!
Score 4
2 Comments:
I thought as much
Thanks
by
If you found this answer helpful, please select "Was this answer helpful? - YES" and/or if this answer solved your problem, please “Choose as Solution”. This allows people in the future to understand which answers helped solve the problem and adds value to the site. - Thanks
by
Add a comment
Add your answer
Lee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 100
