Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1958 Questions View all
Silent mode turning on and off on its own.
About 2 weeks ago my phone started going into ring mode on its own, despite the fact that the vibrate switch is in silent mode. I found that if I press on the front and back of the phone in the upper left corner, I can cause it to vibrate on its own. At this point I have turned it to ring mode because the constant switching between the two modes was running my power down. It has not been dropped, or gotten wet. It really just started happening out of the blue. My question is whether I need to replace the switch or the vibrator. Any recommendations?
Score 1
Add a comment
1 Answer
Most Helpful Answer
I believe you need to replace your audiojack/mute switch ribbon. These things go out easily after some time of use. After awhile, things arent as tight and crisp as they were once before.
Score 1
Add a comment
Add your answer
Milo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 2,364
