Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
How to replace home button?
I need to replace the home button but it looks like you have to pull the glass from the mid frame in order to do so. How do i replace it?
Add a comment
Chosen Solution
Yes, you have to pull the glass
Have a look here:
Well how do you remove the digitizer without damaging it? Ive removed many before but never a perfectly fine one so never had to worry about damaging it
Add a comment
Most Helpful Answer
You need a heat gun or a hairdryer. First remove the LCD screen by unscrewing the screws on the side of the assembly. Then remove the black tape on the inside of the digitizer that connects the glass to the mid-frame. Then with your heat source. work your way around the digitizer on the black part and gently remove the glass working each section at a time.
Score 1
Add a comment
Add your answer
Jared will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 520
