The ACER Aspire E1-572-6870 is a laptop manufactured by Acer in 2013. It is identified by model number E1-572-6870.
5 Questions View all
Screen not responding when cable into the motherboard
When screen cable is plugged into the motherboard laptop isn't powering on. When the cable is unplugged laptop or powering on
Add a comment
1 Answer
Chosen Solution
@chrissmall
sounds like either a bad LCD or a bad cable. You also want to check the cable connector under a microscope to see if there are any pins that are crossing etc. If not then start with a new LCD
Score 1
1 Comment:
Okay thanks I'll check
by
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 57
