Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
153 Questions View all
Why is my screen dimming when it is angled past 30 degrees?
When I lift screen above about 30-40 degrees it dims so that it
can only be read by straining. If kept below above degrees it is normal but basically unusable. It also works fine with an external monitor.
Any help would be greatly appreciated.
bbaker
Add a comment
1 Answer
Chosen Solution
Your PB inverter cable should be replaced. The cable is probably damaged in the display hinge and loose contact when moving the lid. Don't wait too long to do the repair cause the cable could short in the hinge and ruin your logic board.
Here's the part you need:
G4 Aluminum 17" Inverter and Antenna Cables
Score 2
Add a comment
Add your answer
butch baker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 526
