The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
621 Questions View all
Why is my MacBook not running on battery?
I was just using this normally, it suddenly turned off and won’t turn on, I watched a few tutorials on how to fix this and a bit later i tried SMC Reset. It didn’t fix it but I found out that it works when plugged in. I looked at the battery icon and it said “Battery is not charging Power Source: Power Adapter” (When plugged in).
Details I know:
Mac can still read battery percentage
Battery says it’s in good condition
SMC Reset doesn’t work
I haven’t spilled water on it (I saw an article like this but they spilled water, the difference is his MacBook charges the battery mine stays at exactly 41%)
This has been dropped but it was working fine for about a week (This happened just today)
That’s all the details I know that I think can help people understand the problem (and hopefully suggest a way to fix this)
Thanks!
Add a comment
1 Answer
Chosen Solution
With battery percentage and “good” condition correctly reported by the system it seems to be a charging circuit issue. An alternative good working battery would be able to confirm if it’s a logic board fault but would cost you some money that would be in a way lost to get just a confirmation in return. That’s very much up to you to decide if you want to get a confirmation or prefer to invest in a repair that seems would be needed to get the Mac back in fully working condition.
Score 2
1 Comment:
I just got it "Fixed" yesterday. worked normally then when i woke up it returned to using the power adapter as it's source of power... does that mean that the logic board is broken?
by
Add a comment
Add your answer
Mac Cunanan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 55
