CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
418 Questions View all
How do I get my iPhone to turn on?
my iphone vibrated about two hours ago. when i went to check why, the screen stayed black no matter what i pressed. i tried leaving it alone and charging it but nothing would work.
Try a Reset, hold both Home and Power buttons for about 15 seconds until the iPhone turns on.
When you charge it make sure you use the Wall Charger until your problems are solved.
Add a comment
1 Answer
Chosen Solution
Your phone should still be under warranty as it is listed as a Verizon iPhone 4. Just call Apple at 1-800-275-2273 and tell them the problem and they will walk you though the checks and if it is bad they will schedule a repair.
Score 1
Add a comment
Add your answer
chelsea will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 715
