There are three areas you need to inspect with either a magnifying glass or jeweler's loupe.
1. Where the home button connects to the logic board along with the LCD, Digitizer and Camera.
2. Underneath the shield plate under the Home button, the Home button connects with the Home button extension flex that runs under the LCD heat shield.
3. The tiny circuitry on the Home button flex itself as well as the integrity of the flex between the button and the circuitry.
The connectors at either end of a flex, as well as on the logic board, are very delicate and can be damaged very easily. Check for broken pins or debris that may impede contact. Also, the flex on the Home button tears very easily so look for tears or deep scratches. Finally, because you have to peel off the button flex, look for damage in the area where the electronics components reside.
Always disconnect the battery. It should be the first and last step whenever you open your phone.
1 Comment
I disassembled the home button, and I think I did something to the cable. There is a tiny dot, indentation on the initial cable from home button. I have no time to reconnect old screen to home button now, my kids!)) But will try later, thanks for the tip…
by Staton Winter
