Why my iPhone SE is not charging after disassembly?
Well guys, I need some help. Its the first time I disassembly and try to repair a phone. Case was cracked / bent, WiFi / Bluetooth antennas damaged. I fixed those, but now the phone won’t charge.
I tested the battery and it reads out 3.62v, so its empty, but not dead. Current behaviour testing with a lighting cable to the computer and/or charger is that the display turns on, I see that the battery is empty (red) but makes no difference at all. It’s like the iPhone detects the cable plugged in (Indeed it does if I connect / disconnect), but it won’t start the charging process. I tried removing the battery and I get absolutely nothing, so I think the connection between the battery and the motherboard its working as it should.
Ideas about what can it be? Could it be the charging port / flex?
