Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Questions View all
replaced hard drive successfully; but 2 very tiny pins are left over
now 3 very thin stripes appear vertically on right side of screen. Any idea where the pins (which look like mini safety pins) go? I think they are part of the LCD and may fit along the edge - which might be a factor with the thin lines. Any help appreciated
Score -1
3 Comments
These are 1/4" x 1/16" , paper thin clips or springs as they have a bit of flex. They appeared after the hd was installed and I was replacing the LCD. I really think they have to do with the LCD fitting properly, as the thin lines to the right side almost appear to me due to the display not exactly 100% correctly seated.
Thanks for you help.
by
Thanks for your comments, the imac is in my daughter's home. as soon as I get photos of the extra parts and the screen I'll send them up. In mean time I'll tell her to zap the PRAM.
by
Yes, I really hoped the second photo might help. Strange no one can identify. What are the two cables called that connect the LCD to main part of the computer. I think youadvised someone to replace the LVCD cable or whatever instead of replace the LCD.
by
Add a comment
Chosen Solution
The only pins I can think of are actually Torx screws that go into the hard drive screw holes on the bottom facing side of the drive and fit into the rubber grommets to hold the hard drive in place. Look at the bottom of the hard drive here: iMac Intel 24" EMC 2267 Hard Drive Replacement
Update
Here is the photo you emailed me. I've taken this hard drive in and out about three times and never seen anything like it. What else did you remove?
Score 3
5 Comments:
I've torn into this machine and have a lot of unpublished photos but I can't remember anything like what you're talking about. What were the total procedures you did? Can you upload a photo of what you are talking about? I also had screen problems after reassembly but zapping the PRAM cleared it all up.
by
I finally have picture of the two clips that came out after I opened the imac case. How do I post the pictures?
by
At the bottom left of this window is a blue tab that says "Images", click on it and follow the upload directions ;-)
by
I still don't see the blue tab "images" so I sent my photo to your email address. Hope that's okay. Thanks for your help.
by
I did not remove anything else, but I have a hunch they may have popped out when attempting to reattach the fittings to the back of the LCD. If you have a photo of the back of the LCD, either while it is still attached to the
by
Add a comment
This answer was originally to another question.
Those hold the Display data cable in place and prevent it from coming loose. Their not supposed to be removed. They should have two pins on the inside that fit into two holes like a hinge. Your put the cable in then flip them over to hold it in place. I then use some Kapton tape to hold them down.
2 Comments:
Thank you for the instruction on how to replace these pins. Very grateful for your help. I'll google Kapton tape for a source and give it a go in next few week. Do you think these pins have a relationship to the the rainbow thin stripes on far right edge of display?
by
The stripes could be caused by the cable nor being securely in place all the way across
by
Add a comment
Add your answer
p t will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 684
