MacBook Pro models with 13" displays
5405 Questions View all
MBP Crashes all the time. AHT Error 4SNS ICOC?
Hi everybody!
My MBP is crashing all the time while booting. Even when I use the MacOSX Install disk.. it`s crashing. I see the Apple Logo and the rotating ball for some seconds and then it`s crashing.
Then I started Mac Hardware Test. In the detailed Test my MBP crashes and when I start the standard Test while checking the logic board it stops and the message:
"Alert! Apple Hardware Test has detected an error.
4SNS/1/40000000: ICOC-48.730"
I took a pic of it if you want to see it.
I tried all shortcuts at startup. I tried with several hds and rams.
I didn`t find anybody who had the same problem with "ICOC-48.730" extension :(
Do anybody got an idea of what it could be?
Thanks in advance &
greetings
Marco
Update
OK.. dont need to answer anymore. This error indicates some faulty temp sensors and now it`s completely gone.
Topic closed :)
Score 1
Comments:
What was the source of the logic board and just how confident are you that it works?
by
@mayer
thanks for reply.
I bought it at ebay from selling company (jkcomputerparts). I`m not really confident :) they told me it passed their quality tests. It`s under warranty so i`m able to change it, but i thought maybe anybody could say what this error means in detail, i had some hope to get it fixed.
by
I re-installed really everything veeeery carefully. Also checked heatpipe and thermal compound and all connections and cables, everything is fine.
After I was ready the macbook booted one time into MacOSX.. but I directly started again because I wanted to run it through AHT.
When the macbook was running for several seconds it`s gettin warm (normal temp, not hotter than usual) and then it won`t boot anymore.
Even hardware test won`t start.. direct shutdown.
Then I give it some minutes to cool down and tried again.. Then I came into AHT and run the test. First time it shut down, second time it worked with the same error as result.. just a different variable at the end ICOC-52.757 instead of ICOC-48.730
by
Add a comment
1 Answer
Chosen Solution
After some research, the news isn't good from what I've read. That error code basically means your machine is dead. Again, that is just what I read. Does the machine get really hot?
Score 2
Comments:
@Skippy722 1st thanks for your quick reply. No the board isn`t hot and the fan is rotating... This is a replacement board because my original one was broken by water. I changed the upper case incl. keyboard and added a new DC-board and last but not least the logic board. I think I installed everything correctly and worked with earthing on my hands.
by
Add a comment
Add your answer
marco will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,542
