Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3237 Questions View all
itunes Error 1013 Help?
Using the instructions on this link to fix the 1013 error its says to Delete all line that has "gs.apple.com" or something like that and save it but it wont let me save after making changes how do i save it?
http://www.redmondpie.com/fix-itunes-err...
Score 1
Add a comment
1 Answer
Chosen Solution
Jared, not sure which OS you are using, I just used Win Xp and opened the file hosts at Windows/System32/drivers/etc with notepad. where it says Filenamw "*.txt" I changed it to "*.*" which shows me all the files. Now I click on "hosts" It opens it up and shows me all the line items. here I delete all the ones that show ""gs.apple.com" Once they are all deleted, I go to the file menu and select save as "hosts" Now, when notepad saves it, it automatically adds the ".TXT" extension. I close notepad, go to the "Windows/System32/drivers/etc" directory and right click on hosts.txt select rename and delete the ".txt" extension. Now the file is saved as the hosts file. Hope this will help Good Luck
Score 3
Add a comment
Add your answer
Jared will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 699
