Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
71 Questions View all
Why won't my psp go turn on after I reassembled it?
I replaced the screen and had this problem. I put the cracked screen back in, still have no power at all and no light with charger connected. . Checked 7 or 8 fuses under metal shields with meter. Anyone there to help?
Add a comment
1 Answer
Chosen Solution
Blown Fuse maybe?
http://www.mr-vizitkin.ru/images/stories...
^^ Fuses for PSP GO.
The one on the right is for Audio - so the one *under* the metal shielding may well be your power Fuse. I would suggest testing with a multimeter to confirm.
If you are going to bridge it then a Circuit Writer pen is the easiest - just practice on something other than the psp so you get used to the flow.
--I am still looking for suitable fuses to replace mine.
Comments:
i Just had a psp go that the battery was defective - its symptoms are similar to what you describe - i would consider buying a new battery just to eliminate that as a possibility (cost around 6 quid)
by
Add a comment
Add your answer
edward will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 886
