The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
368 Questions View all
How to put the wifi chip on the board?
Hi, can anyone help me how to put the chip back on the board? Should i just solder it or also put termal paste?(can you draw with paint on the picture where to solder/put the termal paste) Or if any better idea can help me with this. Thanks in advance
Add a comment
1 Answer
Chosen Solution
You will want to wick off the original solder and replace it with leaded solder. Apply flux and align the chip the best you can before using hot air on low air speed to solder the chip in place. You may need to go back and touch-up the pins with a soldering iron. You can check if you need to by using a fine tweezer and gently nudging each pin to see if it is soldered in place or not.
3 Comments:
okay thanks, i’ll try your method
by
hello sir, can help me about the hot air. any specific temperature?
by
Your hot air station is going to be different than mine. Leaded solder will melt at 188C/370F. So you can set your hot air at 10-20 degree increments above melting point until you find a good working temperature. It helps if your station has a calibration setting. Practice on a junk board before working on the 3DS.
by
Add a comment
Add your answer
Khairul Asyraf will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 117
