My display image is all a mess!
My Problem is much worse!
Please Help Me!
Please Help Me!
What does the image on an external display look like? If its clean then you’ll need a new display assembly, if the external is also messed up your logic board has a problem.
Either way this is an expensive repair!
Sadly, I suspect you banged the black clutch cover area which pressed against the cable and the T-CON board damaging it which would be the cause of needing a new display assembly. Here’s a view of the connections just behind the cover:
Its one of the two fatter cables that you damaged.
how should I get it done, from apple store or repair from someplace else?
how much will that cost me & will it create problems if I don't get it resolved soon?
I would bring it to an Apple Store. As far as cost its around $700 just for the part.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 49
