A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 Processor. Released October 13, 2015.
96 Questions View all
Possible to replace glue with magnets?
Older iMacs had magnets to keep the screen in place. Wouldn’t it be possible add magnets to the newer iMacs which have the screen glued on? So that when you have to open your iMac the first time, you do not glue it back together but glue in some magnets and some metal and simply snap the screen back in place?
Add a comment
Chosen Solution
Nope, there’s no room. The earlier iMacs has room for a metal plate all around the display and room for magnetic pins. This one does not have the room nor thickness to alter it.
Score 3
2 Comments:
I would love Apple to go back to the magnets. Sadly as @mayer stated just not possible.
by
Too bad. I hoped for the newer, modern neodym magnets.
by
Add a comment
What about magnetic tape?
https://www.amazon.com/Flexible-Magnetic...
I have not tried this myself but I will probably try it next time I have to open up one of these iMacs. Although honestly, I try very hard to not bother. The main thing people want is a larger/faster hard drive and it’s better to use an external (in most cases an SSD) rather than going through the hassle of messing with cutting then replying adhesive.
Add a comment
Add your answer
Skeeve will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 658
