connect charge to MacBook,the light come on them goes out them comes
connect charger to macbook,the lite comes on then goes out,then comes again,but the laptop does not come on.
Check the pins on the AC adapter. Move them to see if they are free and not stuck with a toothpick. Next check the out put with a multimeter. See the pinout on the right side of this link: http://en.wikipedia.org/wiki/MagSafe
Check the magsafe input on the Book for crud and/or corrosion and clean it. Test with another AC adapter. You may need to replace the adapter or the MagSafe board.
I assume you mean the light on the AC adapter. I had this same problem with my MBCD.
Try a different outlet and if that doesn't work buy a new adapter.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 599
