Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1500 Questions View all
LCD Screen not responding properly
I recently replaced the glass and digitizer (pre installed package). Now, after reassembly, the screen does not respond as it should. When I try to touch a particular app, the app to the left of the one I touched is activated. I can't even activate the botoom apps. Any suggestions? Do I need to replace the LCD?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
It is not your LCD. This is usually caused by your digitizer. You can try a restore and see if that makes a difference. If not, reopen your iphone and check all the connectors in particular Cable 2 Touchscreen sensor and home button. Make sure it is connected properly and straight. Good Luck
Score 2
Add a comment
Add your answer
Bill will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 394
