Released by Samsung in March 2016. Model SM-G930.
424 Questions View all
S7 Screen Not Working But Working With Different Motherboard
I have an S7 with no display, it makes noise and you can hear the screen working when you tap it but there isn’t a single pixel lit up, I tried another motherboard on the same screen and its working fine so it isn’t the screen. So it’s something on the motherboard but what would it most likely be?
Add a comment
1 Answer
I would first check the LCD FPC connector on the motherboard. Look for broken, bent, burned, or corroded pins on the connector or loose/broken pads on the motherboard where the connector is soldered to. You might try posting a high-res photo of the board around the connector
1 Comment:
I've looked at the LCD connector and there isn't any damage at all, it's mint. There is no water damage etc as well.
by
Add a comment
Add your answer
Jakob will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 69
