Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
iPhone screw wont unscrew
as i take of the bottom 2 screws to disamble the iphone they come off easily, i come to the screws to take of the lcd panel, i am able to take out 2 screws and the other 3 just wont unscrew at all.. what can i do about this?
is there a way to unscrew them at all? if anybody has the same problem when do you do to take them off?
Score -1
Add a comment
Most Helpful Answer
Are you removing the screws to replace the LCD, if so you have two options
1. drill them out carefully. use a bit just big enough to take the head off the screw. to size it correctly, use a bit a hair bigger then the shaft of the screws that you already removed. Go a little at a time.
2. using a dremel with a jewler's etch, try to make a little groove in the screw and remove it with a flat bladed screw driver
If you are trying to save the LCD, you can use a screw-out, this will save the threads in the LCD from any damage but with destroy the screw.
On any option available, you are going to need new screws.
Score 1
2 Comments:
The screw holes are on a piece of sheet metal that is lightly glued to the back of the LCD. Ruining this is fine, it can be replaced.
by
Thank u so much..... And yes I was talking about the 5 screws..
by
Add a comment
Where do you see screws? There are only the two to take the screen off. Do i misunderstand the query?
1 Comment:
i think he means the 5? screws on the midframe of the LCD/digitiser...? time for a very small drill bit and a steady hand
by
Add a comment
Thank this was very helpfully and also 1 more question what are some quality tools I can get? What's recommended the ones I only can find are $2 and they seem like they don't fit it's Chinese *#@#.
3 Comments:
What tool are you looking for? are you looking for a rotary tool, a drill, a screwdriver...
by
Was just looking for quality tools to fix a iPhone, a screwdriver and a drill
by
for screwdrivers, i highly recommend the 54 piece bit driver kit. for a drill, go to your local hardware store and ask them what never comes back. If tools go back all the time for replacement, then i would stay away from those.
I'm in Canada, so I migt not have the same available tools as you do. I know that I really trust Makita, but again, I don't know if you have access to it where you are.
by
Add a comment
i cant get the screw out either what did you do?
Add a comment
Add your answer
logan62589 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,892
