Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Questions View all
Newly replaced battery crashes at ~30%; suspicious battery levels
Hi all,
I have just successfully* replaced my MacBook Pro Mid 2014 battery using the iFixit guide and kit. I am noticing now two main issues, which I assume are interconnected:
  • When running on battery, the computer crashes at ~30% and cannot be powered back on until it is plugged in with the AC adaptor.
  • The displayed battery levels & charge times on the menu bar are suspicious.
    • I have *just* plugged in my device and it is at 28% with an expected charge time of 8:25 until full.
    • While infrequent, I have seen the displayed battery level % jump from the 25-30% threshold up to 50-70% for a moment before jumping back down
I suspect (and hope) this is a calibration issue.
Steps I have taken thus far:
  • Initial calibration (charge to full +2 hours; drain battery and wait 5 hours; charge up to full)
  • Reset SMC
  • Reset PRAM
  • Checked System Info - Power (see attached screenshot)
Thank you for your help!
Add a comment
1 Answer
Chosen Solution
You’ll need to get a replacement as yours is defective!
Score 2
2 Comments:
Hi Dan,
Thank you so much for your help. I am writing the iFixit Team now regarding the issue.
In your experience, is there a simple way to use 1st or 3rd party diagnostics tools to 'show' the problem with a battery?
by
Add a comment
Add your answer
Keenan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 138
