If you crack the white part of your iPhone 7 is it still waterproof
Internally (mostly) cracked the bottom white part of my phone
I presume you are referring to the glass face of the device. At any rate, iPhones are barely water resistant [1] in the first place, they are certainly not, nor never were, waterproof.
If the glass is cracked, or the screen was replaced, you should do everything possible to avoid contact with water.
[1] Your iPhone (ed. - iPhone 7 and later) is splash, water, and dust resistant and was tested under controlled laboratory conditions with a rating of IP67 under IEC standard 60529. Splash, water, and dust resistance are not permanent conditions, and resistance might decrease as a result of normal wear. Liquid damage is not covered under warranty.' - per Apple''
https://support.apple.com/en-ca/HT207043
What does IP67 mean?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 307
