The HTC Vive controller can be identified by its model number: 2PR7100. It is a first generation motion controller released by HTC on April 5th, 2016 as an accessory part of the Vive Virtual Reality set.
The inside of my HTC Vive Controller charger fell out...
The inside of the USB type C charger fell out and now the controller will not charge, how can I fix this?
Add a comment
1 Answer
You would have to buy a new micro usb connector and unless you're very good with soldering and have a micro soldering tip it would be challenging. Finding the correct connector if you use your current one to look for which type you need. It looks like one with 4 through hole mounts and the standard pin out for the charger.
Add a comment
Add your answer
theodore may will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 118
