Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
559 Questions View all
Video card or logic board issue
This iMac boots to hard drive and I can connect remotely with screen sharing, I run system profiler and check the Graphics/displays and it shows nothing connected does not show the video card. There is no display, sometimes I get a gray flickering screen and other times I get the black screen, I tried the external output with a dvi to VGA adapter and get no output to the monitor, ( I verified that the ext monitor and adapter operate with my working machine) LED 1 on, LED 2 on, LED 3 on, LED 4 sometimes is on and other times not (???). I reseated the video card and double checked all connections. I am unsure which part has failed on this unit any input is appreciated, and many thanks in advance running OS X 10.6
Score 1
Comments:
I replaced the LCD cable as a precaution (the old one looked shorted) with no result I will try replacing the inverter as the next step, but the no video output to the dvi leaves me suspicious of the video card I will check back in with results, thanks
by
I just wanted to give an update so that this information can help someone with the same symptoms, scince I was able to use the share screen feature to verify the main board and Hard drive were operating and found that the system profiler was telling me that no video card was present, I obtained a replacement video card and the problem was solved. The machine is now in working order, I ran tech tools to verify all hardware and passed with flying colors. I am guessing that whatever component has failed on the old video card was fooling the logic board into allowing LED 3 to light up and LED 4 to light intermittently.
Problem solved with New video board.
Thanks to everyone and hope this helps someone else.
by
+ Very well done !
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
LED #4
Indicates that the computer and the LCD display panel are communicating. This LED will be • ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Score 5
Add a comment
Add your answer
junvaz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,365
