Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
I see image but the touchscreen wont respond, after replacement?
i have a feeling that the #2 tab was loose,and the glass comes of instead of the touch screen( i think the sticky pad lost its stickiness),
Add a comment
1 Answer
Chosen Solution
check you have the right part..the 3g and 3gs are not interchangeable and it may be why the tab is loose. the touch screen doesn't have to be in contact with the lcd to work, but you may like to purchase a precut adhesive strip to keep it all together-you'll have to remove all the old adhesive first.
try a hard reset..home and power button held together for 10 seconds, then release and allow to reboot.
Score 3
Comments:
like pollytintop saysMake sure you have the right part
by
Add a comment
Add your answer
JUMPMANJAY23 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,109
