Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
41 Questions View all
Why does my motor fan not work?
my car was over heating so i replaced the thermostat.... turns out the fan does not kick on...how do i fix this?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
There is a switch in your thermostat housing that may not be working. You can use a multimeter to see if the switch closes at temperature. Also check the fan motor itself. I used to do it by applying power directly to the electric motor to see if it works. Not a terribly expensive or tough repair and should be doable in the drive way :-)Let me know if you need a copy of the service manual for the cooling part. Good Luck
Score 4
Comments:
good answer +
by
I thought so, but I guess Sara Perez did not ;-)? Have not heard back to see if it worked. It would be nice if we would all get a bit more feedback just to make sure that our advise worked or what else is needed....Oh well ;-) Thanks remacberlin
by
Add a comment
I am not the original person who posted this but I have the same problem, I jumped the thermo switch plug and the fan came on,
Add a comment
Add your answer
Sara Perez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 36
All Time: 5,300
