Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
After replacing front and bettary, 3G and GPS signal is weak.
Dear all.
Hello. please help me!
I replace front glass ,LCD and battery of my iPhone. it works perfectly, however, the 3G and GPS signal is too weak (or no signal frequently) I check the small golden pin which should attached at the side of iPhone, but it still get weak signal.
Please help me! Thank you .
regards.
Score -1
1 Comment
3GS iPhone has 2 small golden pins that contact the bezel. One from the Logic Board and one from piece with #7 connector. Also make sure #7 is connected.
by
Add a comment
Most Helpful Answer
Is your #7 ribbon attached? If it isnt then there is your problem.
Score 1
Add a comment
Check to make sure the little pin by the "do not remove screw" is making contact with the frame.
Add a comment
Add your answer
Dongyoung Kim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,553
