Battery Indicator Says not Charging
Spilled some cofee on the MBP and let it dry out with a fan for a few days and it would not power on. I opened it up, pulled the battery and logic board and gave it a thorough cleaning with non-conductive electronics cleaner. Put er back together and it powered up but says the battery is not charging in the indicator.
The side LED indicator shows nothing when I push the button and when I took it apart I noticed some corrosion on the indicator so I cleaned it as well.
Do you think the battery is fried or could it potentially be a corroded connection form the power source/indicator/logic board to the battery?
Update:
I just ran the built in hardware test and this code came up:
4SNS/1/C0000008:TN1D-124
I did some research and I think it has to do with a faulty temp sensor which would make sense why my fan would be running higher....also to the first answer I accidentally responded in the answer section after you.
Thanks for the info...took it into the mac store diagnostics showed problems with the logic board, battery, memmory, and bluetooth. I think it all stems from the logic board problems probably....and most likely they will find water damage so looks like no macbook pro anymore...
by Connor
