App Store crashing with "JetEngineMac PlugIn" error.
I recently upgraded my stock Macbook Pro’s RAM and HDD from 4 GB of RAM to 16 GB and from a 500 GB 5400 rpm HDD to a 1 TB Samsung EVO SSD.
When attempting to open the App Store, it does not open and instead an error stating “App Store quit unexpectedly while using the JetEngineMac plug-in.” I have ran the hardware test and no errors arise. Installation of MojaveOS went smoothly without errors. Installation only took ~30 minutes.
4 Comments
Did you upgrade the HD SATA cable to the newer version?
FYI: Your Hard Drive Cable Is A Ticking Time Bomb
I've been pushing this for quite a few years! You also need to not crease the cable as the fragile foil wires of the ribbon cable can be easily damaged. You want smooth arcs around the corners.
by Dan
That broke on me back in 2014 and replaced it.
by Adrian Soto
have you ever upgraded the hard drive
by mayer
Prior to this moment? No.
by Adrian Soto
