MacBook Pro doesn't always boot. Battery doesn't charge.
Hi all!
I discovered I had a bad logic board, nvidia GPU problem, so I reflowed it.
Now when I try to turn my MBP on it doesn't respond.
Nothing! Completely dead.
BUT!
I can get it to boot after doing this.
- unplug the battery and the magsafe.
- hold the powerbuttom down for about 10 sec.
- while still holding the powerbutton down I insert the magsafe powercable and continue to hold the powerbutton down for another 10 sec.
- after 10 sec I release the powerbutton and press it again. And it boots!!!
But now the fans are going on full blast all the time and the battery doesn't charge.
My keyboard, powerbutton and other lights isn't working but now the MBP works like it should.
I've tried to reset the PRAM and SMU but when I have to reset the SMU where you should remove battery and magsafe, hold button for 5 sec and then turn it on again, it won't boot that way.
I have to do the method I described earlier.
I reflowed the logic board in the owen very carefully but maybe something else got damaged on the way.
Anyone else who have had these kind of problems?
1 Comment
Glas you solved your problem
by mayer
