My tv won’t turn/power on after being unplugged for a couple of hours
I moved my tv and then moved it back to put it back on and plugged the tv back in, no lights or anything came on when I plugged in back in. I have changed the fuse in the plug, the power cable and the socket.
Score 1
2 Comments
I had the same problem with our sony. later on we found out that it was a burned out screen bulb in the tv. We took ours for a tv trade in to get money off our new tv.
by
Hi @k12 ,
What is the model number of the TV?
by
Add a comment
Most Helpful Answer
Hello,
If you had been check a all things means cable and power supply then you should talk to your customer service and talk to where you purchased it.
Score 1
Add a comment
get it checked from some professional technician or if your product is under warranty, take it to the service center maybe some internal problem is causing this issue.
Add a comment
Add your answer
Kier will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 851
