Starting at only 5.54 lbs (2.51 kg), the incredibly thin, superportable XPS 15z will keep you on the go for up to 8 hours.
How do I replace the LCD cable to stop the LCD flickering problem?
I’m doing a project of fixing my old Xps 15z laptop starting by replacing the screen and the connector cable from the LCD to the motherboard (provided that it isn’t soldered).
Add a comment
Chosen Solution
Hi,
Here’s a link to the service manual for the laptop.
Scroll to p.81 to view the necessary pre-requisite steps and then the procedure to remove the display assembly. This will enable you to remove / replace the LVDS cable.
Replacement cables are available online. Just search for Dell XPS 15Z LVDS cable to get results for suppliers of the part.
Score 1
Add a comment
Just an FYI, you may want to disable the Dynamic Refresh Rate settings in the Intel graphics program. I was having horrible screen distortion when running on battery, and after disabling it by unchecking the box it was fixed!
Add a comment
Add your answer
Diego Toledo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 447
