connects to tv but not monitor
i own a optiplex 760 usff , it succesfully connects to tv’s using dvi to hdmi, but not dvi to dvi for my monitor
pls help
pls help
Based on your responses in this thread, I suspect a DVI-I (male) to DVI-D(Female) may do the trick, the adapter itself is ~$3 online
indeed i believe so too
If your monitors support HDMI, maybe just keep the connection of DVI to HDMI.
Good luck!
well thats the thing i have no hdmi monitors only 15pin vga and dvi
Does the machine have VGA? Because if so, you can use that connection.
my desktop ony has 9 pin vga and dvi
ok, so i looked the optiplex has a dvi-i port but the dvi cable and the dvi to hdmi boh are dvi-d
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 155
7 Comments
Hi @fegelein3290 ,
What is the make and model number of the monitor?
What resolutions does it support?
Have you tried a different DVI cable?
by jayeff
Do you know for sure the monitor works? Have you tried switching inputs on the monitor?
by Derek Osmulski
yes ive tried a lot
by Brayden S
ive tried on 3 different monitors actually
by Brayden S
Are you using the same DVI cable among the 3 monitors as well as the TV? What pin style is the DVI cable you are using vs the pin style on your Optiplex vs the DVI pin style of the TV?
by Casey
Show 2 more comments
