Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
How to fix the touch screen sensor on a 3g?
on the iphone 3g how do you fix the touch screen sensor? the glass is not cracked just the sensor is not working when i touch it, how dop i go about fixing this.?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Follow THIS guide to check that the cable is plugged in correctly. If all appears correct and the touchscreen does not respond, you may need to replace the touch screen assy
HIH
Add a comment
Add your answer
logan62589 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 17,015
