A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563 Questions View all
Why doesn't it show the battery symbol on MacBook Pro
So my problems are: It won’t show batter symbol when I log in but it does in the log in menu but it has a x in the middle. Whenever I unplug the charger it just shuts down. SMC doesn’t work. Please help.
2 Comments
Is the X red or black?
by
It is a black x
by
Add a comment
1 Answer
Most Helpful Answer
Make sure you use the orginal Apple charger and the USB-C cable. I do strongly recommend you get a Power Meter for Type C Devices so you can monitor whats happening.
Sadly, your logic board likely needs repairs or replacement depending on what happened. Did you have a liquid spill or bang your system damaging the bottom cover?
Are you able to repair your own system?
Score 1
1 Comment:
Alrighty, I do have the original charger and I even got a new one (spare). And I did damage the bottom cover as it has scratches and dents, but it was many months ago. Does all the problems start coming long after it got dent? I guess I have to go to the genius bar?
Also when I first noticed the problem, the battery showed but it was stuck at 15% and would die if I unplugged it but after doing a smc reset (i think) it didn't show the battery anymore, and that is where I'm now. Is that supposed to happen?
by
Add a comment
Add your answer
Daniel Chen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 72
