Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
Display broken, Restore fails: Replace LCD+Digitizer?
0
Score
Avatar
Froobaer
Asked
42 seconds ago
History • Edit • Delete • Add Comment
Hi,
I felt down on my iPhone 3G and it switched off. The display has a small spot under the glass, which looks malformed and shows rainbow colors -- at a very close look.
After the boot process, the screen shows weird white and grey lines and flickers.
After connecting it to the MacBook, iTunes asks me to restore it. However, the restore process fails with an unkown error (1604). It tried it serveral times.
Should I order a new lcd and digitizer unit from ifixit, or should I put my iPhone into the bin?
Best,
Foobaer
This is the iRecovery log file:
[NAND] Device ID 0x1ed5a968
[NAND] BANKS_TOTAL 2
[NAND] BLOCKS_PER_BANK 8192
[NAND] PAGES_PER_BANK 1048576
[NAND] SECTORS_PER_PAGE 8
[NND] BYTES_PER_SPARE 216
[FTL:MSG] Apple NAND Driver (AND) RO
[FTL:MSG] FIL_Init [OK]
[FTL:MSG] BUF_Init [OK]
[FTL:MSG] FPart Init [OK]
read old style signature 0x43303035 (line:403)
[FTL:MSG] VFL Register [OK]
[FTL:MSG] VFL Init [OK]
[FTL:MSG] VFL_Open [OK]
[FTL:MSG] FTL Register [OK]
[FTL:WRN] Failure running _LoadFTLCxt!
[FTL:WRN] Recovering NAND Data Structures - this will take some time!
[FTL:WRN] _FTLRestore OK!
[FL:MSG] FTL_Open [OK]
Boot Failure Count: 15 Panic Fail Count: 1
Entering recovery mode, starting command prompt
This is the iTunes restore log:
2011-06-08 21:31:57.000 iTunes[5714:207]: restore library built Feb 8 2011 at 13:47:23
2011-06-08 21:31:57.000 iTunes[5714:207]: iTunes: iTunes 10.3.1
2011-06-08 21:31:57.000 iTunes[5714:207]: iTunes: Software payload version: 8C148
2011-06-08 21:32:52.000 iTunes[5714:f017]: iTunes: Specifying UOI boot image
2011-06-08 21:32:52.000 iTunes[5714:f017]: *** UUID XXXXXXXXXXXXXXXXXX ***
2011-06-08 21:32:52.000 iTunes[5714:f017]: amai: AMAuthInstallSsoInitialize: can't find SSOClient.framework
2011-06-08 21:32:52.000 iTunes[5714:f017]: requested restore behavior: Erase
2011-06-08 21:32:52.000 iTunes[5714:f017]: amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/tmp/PersonalizedRestoreBundle.jBFogaqvL5/amai/debug/tss-request.plist
2011-06-08 21:32:52.000 iTunes[5714:f017]: amai: AMAuthInstallHttpMessageSendSync: httpRequest=<CFHTTPMessage 0x1e3ab80>{url = http://gs.apple.com:80/TSS/controller?ac...; request = POST /TSS/controller?action=2 HTTP/1.1}
2011-06-08 21:32:54.000 iTunes[5714:f017]: amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.0.0)
2011-06-08 21:32:54.000 iTunes[5714:f017]: amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/tmp/PersonalizedRestoreBundle.jBFogaqvL5/amai/debug/tss-response.plist
2011-06-08 21:33:00.000 iTunes[5714:fe1b]: iBoot build-version = iBoot-931.71.16
2011-06-08 21:33:00.000 iTunes[5714:fe1b]: iBoot build-style = RELEASE
2011-06-08 21:33:00.000 iTunes[5714:fe1b]: DeviceRequest failed: 0xe000404f
2011-06-08 21:33:00.000 iTunes[5714:fe1b]: command device request for 'getenv radio-error' failed: 2008
2011-06-08 21:33:00.000 iTunes[5714:fe1b]: radio-error not set
2011-06-08 21:33:00.000 iTunes[5714:fe1b]: unable to open device_map.txt: No such file or directory
2011-06-08 21:33:00.000 iTunes[5714:fe1b]: <Recovery Mode Device 0x1e5d540>: production fused device
2011-06-08 21:33:00.000 iTunes[5714:fe1b]: <Recovery Mode Device 0x1e5d540>: operation 4 progress -1
2011-06-08 21:33:00.000 iTunes[5714:fe1b]: bootstrapping restore with iBEC
2011-06-08 21:33:00.000 iTunes[5714:fe1b]: <Recovery Mode Device 0x1e5d540>: operation 31 progress -1
2011-06-08 21:33:01.000 iTunes[5714:fe1b]: <Recovery Mode Device 0x1e5d540>: Recovery mode succeeded
2011-06-08 21:38:01.000 iTunes[5714:dc17]: iTunes: Restore error 1604
2011-06-08 21:44:54.000 iTunes[5714:207]: device disconnected (isDFU = 0)
2011-06-08 21:44:54.000 iTunes[5714:207]: _AMRecoveryModeDeviceFinalize: 0x1e5d540
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
have a look at this and see if it helps http://forums.techarena.in/guides-tutori...
Score 2
Add a comment
Add your answer
Froobaer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,672
