Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
LCD Backlight not working if battery over 80% charged
I have a rather unique problem i have cracked an replaced the lcd + digitizer the problem appears both with the cracked LCD and a new one so i am assuming i messed up something on the board itself
THE LCD BACKLIGHT IS NOT WORKING WHEN CHARGED OVER 80% go figure
Can anyone help?
Score -1
1 Comment
Weird. Never hurts to try a Reset. Hold together Home and Power buttons for about 15 seconds, let iPhone turn off itself and then it will turn back on.
by
Add a comment
1 Answer
Chosen Solution
It may be a heat related issue - check for loose connections. Does the battery look swollen? It may be expanding a little when hot?
If not then you may need to replace the display
iPhone 3GS Display
[linked product missing or disabled: IF142-002]
iPhone 3GS Display Image
Product
iPhone 3GS Display
$19.99
iPhone 3GS Battery Image
Product
iPhone 3GS Battery
$14.99
Score 1
Add a comment
Add your answer
Hrvoje will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,633
