Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1961 Questions View all
Help! Device reboot suddenly? every 3 minutes!
Hi,
The iPhone had water damage, and the LCD had no light afterwads.
but the Device worked! just without light.. (Phonecalls and all functions/buttons for over a week).
I replaced the LCD with a fixed LCD screen that I took from another device, that worked fine as well..
I also made restore to the latest FW - 4.3.3
Now.. I turned on the phone, and after using the phone for 3 minutes, it reboot itself :/
Anybody has an idea what to do???
Thanks
Add a comment
MacBook Battery Fix Kits
Starting at $69.99
Buy Now
Starting at $69.99
Buy Now
Chosen Solution
Change your battery, the water damage more than likely killed it. While you're in there, clean the board up with 99% alcohol if possible
Score 1
Comments:
Thanks a lot man :)
by
No problem, best of luck.
by
Add a comment
Problem probably occurred during your restore. The phone has lost its baseband files.
Do a restore in DFU mode
Add a comment
Add your answer
Shai will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,388
