Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
744 Questions View all
Why doesn't my primary rear camera module work?
Dear Community,
I have an iPhone 7 Plus, which is unable use the rear camera module connected to the primary connector. If I open the offical Camera app I can change between the front facing and the rear cameras, the front one works well, but the rear main is only working when I enable the secondary lens with the ZOOM 2x button. I am not able the use the LEDs as flashlight / torch, but they work fine with the secondary lens. I swapped the camera module from another phone, I see the same symptoms. Any clue?
Add a comment
iPhone Battery Fix Kits
Only $29.99
Buy Now
Only $29.99
Buy Now
1 Answer
Chosen Solution
If you tried a known-good camera and it didn’t solve the problem, then the issue is on the logic board. The rear camera is a fairly complex piece of hardware, with a zoom camera and a regular camera. They each require multiple voltages to work so if one of the voltage rails for the regular camera is not working, then that camera will not work and the flash will also not work.
This will require some board-level troubleshooting and most likely a micro-soldering repair.
Score 5
Add a comment
Add your answer
Takács Miklós will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 31
All Time: 75
