Help Identifying and Replacing Acer E-15 SMD Battery Connector
Hello. While replacing the battery for an Acer Aspire E-15 I accidentally bent some of the battery connector pins. I have experience soldering, so would it be possible to replace this component? The connector is the component outlined in red in the following image:
. Based on my preliminary research, I believe this connector is the C114F3-108A1-L_Batt_Conn part in the schematics. Can someone confirm this? If this is indeed the component, where would I purchase one of these connectors? Is it even possible to replace this component? Thanks in advance.
I presume you've tried gently bending the pins back. Hard to be sure from your picture but it looks like the red and black wires (at least) are duplicated so it's possible you could afford to loose one of each if they broke off. But if they're only commoned on the motherboard and not in the battery, you might then find you only had half the battery pack connected.
by Philip Le Riche
